A new PSU
6 May 2009
I currently have a Hiper Type R 580watt PSU. Ive had it for around 5 years and never had a problem with it. I'm thinking of upgrading to a GTX480 graphics card and have heard that in the past Hiper PSUs take components out with them.
I'm currently powering a [email protected], 4 hard drives and 1 dvd drive on my Hiper
Is this a good investment or is there something better for a similar price?
http://www.overclockers.co.uk/showproduct.php?prodid=CA-149-AN&groupid=701&catid=123&subcat=
Thanks
no lol got 3 kids and theyve got a pc each 2 whom have a corsair 650 psu me and other son have the corsair 850
you may keep the psu longer than the other parts, so it is nice to have a psu with headroom for any eventuality.
Is the only difference between the hx650 and tx650 that the hx is modular? (and £20 more expensive)
the HX has a few extra connectors too for graphic cards.
it is almost very similar to the Antec new truepower 650.
and the XFX too, which isn't modular.
This one?
http://www.overclockers.co.uk/showproduct.php?prodid=CA-117-AN&groupid=701&catid=123&subcat=1088
Is this one the same...
ANTEC 650W TruePower ATX Power Supply Unit
The Antec 650W TruePower ATX Power Supply Unit features a 120mm PWM fan to provide maximum airflow with significantly less attendant noise - 50% less than standard fans!
Antec's NVIDIA SLI ready 650W TruePower ATX Power Supply Unit also boasts 4 +12V output rails for safety and stability, as well as an Active PFC to ensure the highest levels of energy efficiency. In fact, the 650W TruePower ATX Power Supply Unit is 80PLUS Bronze Certified, to prove it!
What's more, there's even advanced hybrid cable management, to reduce clutter and further maximise airflow.
Equip your system with the Antec 650W TruePower ATX Power Supply Unit and enjoy advanced PC performance!
Technical Specifications Power Supply Norm ATX
Power 650W
Outlet Connector(s) 1 x 20+4 Pin
1 x 4 Pin ATX 12V
1 x 8 Pin EPS 12V
2 x 6+2 PCI-E
2 x 6 Pin PCI-E
9 x SATA
9 x Molex
1 x Floppy
