Hi all.
Ive been playing some crysis and have noticed that in scenes where there are a lot of combat, the frame-rate seems to drop dramatically to the 20's and rarely even lower than that. Some of the levels run fine, around 40-50 fps, but the ones where there is a lot of combat or a lot going on, the fps is quite low. My other games, such as bad company 2, dragon age and oblivion seem to run fine.
Im aware that crysis is a very demanding game, but I dont think I should be struggling to run it like i have been. I play the game at 1440x900 res with 4xaa although ive tried it with 0xaa and didnt notice a difference in frame-rates. The game is patched to 1.2 and im using the latest nvidia drivers. My specs are in sig but if you cant see them, il write them down anyway. For a period, I had my CPU at 3.6GHz, but lowered it back after my system decided to crash the other day. the 3,6GHz didnt really improve the performance in any noticable way.
AMD Phenom II X4 955 3.2GHz CPU
4GB DDR3 1333MHz RAM
Gigabyte GTX570 with 266.58 drivers
Asus M4A80GTD Pro/USB3 Motherboard
500GB 7200RPM SATA II HDD
Windows 7 X64 Professional
750TX Corsair PSU.
My max temps for CPU are 48oC and GPU gets to 81oC under Furmark. I know the GPU temp is fairly high but its still within safe range.
750TX Corsair PSU.
