HTC 7 Pro Last minute choice before I buy......
16 Jul 2008
London
Always been a fan of windows mobile for probably the last 10 years, about to buy the HTC 7 Pro from Amazon for £450, before I buy is there any other windows phone I should consider or do you think I have made the right choice?
Thanks
What sarge said, its also worth noting the new Windows mobile is NOTHING like it was 10 years ago, its much better but you might not think so :p
So basically your saying the only benefit over the HTC 7 Pro is that I have a keyboard, although I love my keyboars maybe £150 more isn't worth it then.............. oh decisions decisions
The Omnia 7 is much much better than the HTC 7 Pro unless you HAVE to have a keyboard. For what its worth, the WP7 keyboard is superb and easy to use.
Its up to you.
None really at the moment as all the new ones come out in a few weeks (or less).
If you really want to get one now, the HTC Desire/Samsung Galaxy S are your best bets as they are available relatively cheaply.
The HTC Desire HD/Google Nexus S aren't really worth looking at as they will cost the same as the new top spec phones that are due to be released very soon.
