Hello all,
On the brink of building the following HTPC:
Antec Fusion Remote HTPC Case
AMD Phenom II X4 Quad Core 965 Black Edition "125W Edition" 3.40GHz
Gigabyte GA-880GM-UD2H AMD 880G (Socket AM3) microATX mobo
GeIL 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Dual Channel
Scythe Shuriken BIG Quiet Low Profile CPU Cooler
Corsair Builder Series CX 500W ATX Power Supply
LiteOn iHBS112 12x BluRay-RW / 16 x DVD±RW Drive - Black (OEM)
Creative Sound Blaster X-Fi Xtreme Audio 7.1 Sound Card
"Seagate Barracuda 7200.12 1TB SATA-II 32MB Cache (x 2)
TP-Link 300Mbps Wireless-N USB Adapter
Note that I'll either use the on-board GPU or a spare radeon HD 4770 which I have lying around. I may also add a tv card but not yet decided on that. Is there anything else I might have missed?
The other issue I have relates to the sound. In the summer I'll invest in a full blown sound system (i.e. amp + separates) but until then, I don't know whether I should put up with the sound from my tv or invest in an interim solution (e.g. £100ish such as the AE Aegos). If I do get the speakers, then I assume that I won't need a soundcard since I can just hook up the speakers to the tv and passthrough the sound from the pc to the tv (and subsequently the speakers) via HDMI?
Would be grateful for your advice.
Many thanks.
Many thanks.
