- 20 Jul 2009
- Midlands
Today OcUK have expanded the range of AMD motherboards from the likes of ASUS and MSI with Gigabyte to follow. Heres a small selection of some of the new lines coming into stock
MSI 870A Fuzion Power Edition (Socket AM3) DDR3 PCI-Express ATX Motherboard @ £119.99 inc VAT
Military Class series products feature top components that offers users the best experience for its unparalleled quality, ultimate efficiency, and the cool & noiseless and safety for its unbeatable stability.
Powered by MSI Fuzion Technology, MSI Fuzion Series MBs offer Non-Identical & Cross-Vender Multi-GPU Processing; which allows users to install any 2 different level and brand graphics cards in a single system. The technology can perform scalable rendering to deliver near-linear gaming performance by load-balancing graphics processing tasks.
Specifications
- Support for AMD Phenom II X6/X4/X3/X2, Athlon II X4/X3/X2 and Sempron CPU
- HyperTransport 3.0 supporting speed up to 5200MT/s
- AMD 870 and SB850 Chipset
- Lucid LT22102 Chipset
* This chipset supports A-mode, N-mode and X-mode, X-mode can only work with Microsoft Windows 7
- 4x DDR3 1066/1333/1600* (OC) DRAM, 16GB Max
- 2x PCI Express 2.0 slots (X16, x16)
- 3x PCI EXpress x1 slots
- 1x PCI slot
- 6x SATA-III (6Gbps) ports support RAID 0, 1, 5 & 10 modes
- 1x USB 3.0 port
- 12x USB 2.0 ports (6x Internal, 6x Back Panel)
- 2x IEEE1394 Firewire ports (1x Internal, 1x Back Panel)
- Flexible Realtek 8-channel HD audio with jack sensing
- Gigabit LAN
Only £119.99 inc VAT.
ORDER NOW
MSI 880GM-E41 880G Socket AM3 onboard graphics 8 channel HD audio mATX Motherboard @ £49.99 inc VAT
Superb Stability: Military Class Components
OC Genie: Easy Overclocking Technology
Unlock CPU Core: Unlock hidden CPU core and potential
Lossless 24bit/192kHz HD Audio
Specification
- CPU: 64bit AMD® Phenom II X6/X4/X3/X2, Athlon II X4/X3/X2 and Sempron CPU.
- HyperTransport: 3.0 supporting speed up to 5200MT/s
- Chipset: AMD® 880G and SB710 Chipset
- Memory: Supports four unbuffered DIMM of 1.5 Volt DDR3 800/1066/1333/1600*/1800*/2000*/2133* (OC) DRAM, 16GB Max
- Slots: 1 PCI Express x16 slot with x16 operation (PCI Express Bus SPEC V2.0 compliant), 2 PCI EXpress x1 slots, 1 PCI slot, support 3.3V/ 5V PCI bus Interface.
- SATA-II: 6 SATA II (1~6) ports by AMD® SB710
- RAID: SATA II 1~6 support RAID 0, 0+1, JBOD mode by AMD® SB710
- Audio: Flexible 8-channel audio with jack sensing, Chipset integrated by VIA® VT1828S
- LAN: Supports 10Mb/s, 100Mb/s and 1000Mb/s
- Dimensions: 24.4cm(L) x 22.0cm(W) Micro-ATX Form Factor
Only £49.99 inc VAT.
ORDER NOW
MSI E350IA-E45 E-350 with HD6310 iGPU - AMD Fusion (ITX) @ £99.98 inc VAT
MSI E350IA-E45 E-350 with HD6310 iGPU is based on AMDs new Fusion technology. Featuring All solid caps for high reliability and ultra endurability the MSI E350IA-E45 is the perfect fully integrated low power solution.
Specifications
- Processor: AMD Dual-Core E-350 (1.6GHz)
- Chipset: AMD Hudson M1 FCH
- Memory: 2 DIMMs support for DDR3-1333/1066/800 MHz up to 8GB Max
- Video: Built in AMD 6310 (HDMI + D-SUB out)
- Audio: 8 Channel (7.1) HD Audio subsystem with S/PIDF
- LAN: 10/100/1000 Mbits/sec LAN subsystem
- Connectivity: 4 x SATA 6Gb/s. 2 x USB3.0, 10 x USB2.0.
- Internal Expansion: 1x PCI-Express x16 slot (x4 speed)
- ITX
Only £99.98 inc VAT.
ORDER NOW
Asus AMD E35M1-M PRO Hudson M1 Integrated Dual Core Zacate 18W APU SATA-600 DDR3 mATX (Fusion) @ £109.99 inc VAT
The latest motherboard from AMD supports an integrated dual-core AMD® Zacate™ 18W processor. This revolutionary APU (Accelerated Processing Unit) combines CPU processing power and advanced DX11 support graphics in a minimalist, energy efficient design to enable accelerated performance and an industry leading visual experience. The E35M1-M Pro features single-channel DDR3 1066 memory support and accelerates data transfer rates of up to 2.5GT/s.
AMD® Hudson M1 FCH is designed to support up to 2.5GT/s interface speed as well as PCI Express 2.0, x 16, graphics. The AMD Hudson M1 Chipset natively supports next-generation Serial ATA (SATA) storage interface, this motherboard delivers up to 6.0 Gb/s data transfer rates. Additionally, users can gain enhanced scalability, faster data retrieval and double the bandwidth of current bus systems. It supports 5 x SATA 6Gb/s ports + 1 E-SATA 6Gb/s Port and 2 x USB 3.0 Ports + 12 USB 2.0 Ports.
Users can enjoy Full HD 1080p multimedia home theatre entertainment, with HDMI that delivers multi-channel audio and uncompressed digital video for Full HD 1080p visuals through a single cable. The E35M1-M supports HDCP copy protections such as HD DVD and Blu-ray this combined with HDMI provides you with the highest quality home theatre experience.
This motherboard uses 100% high quality conductive polymer capacitors on-board for durability, improved lifespan and enhanced thermal capacity.
Key specification
- APU: Integrated dual-core AMD® Zacate™ 18W processor with up to 2 "Bobcat" cores,DX11 GPU,FT1 BGA
- Chipset: AMD® Hudson M1
- System Bus: Up to 2.5GT/s; UMI Link
- Memory: 2x DIMM, max. 8GB, DDR31066,non-ECC ,un-buffered memory with Single channel memory architecture
- Graphics: Integrated AMD® Zacate™ graphics with Max. UMA Memory Size: 1G via DVI, HDMI with HDCP and RGB.
- Expasion slots: 1 x PCIe2.0 x16@X4, 1 x PCIe2.0 x1, 2 x PCI 3.0
- Storage: 5SATA 6Gb/s, 1eSATA Supporting RAID 0 , RAID 1,JBOD
- LAN: Realtek® 8111E Gigabit LAN
- Audio: ALC887-VD2 High Definition 8-channel Audio (3jacks) with Optical S/PDIF out port at back I/O
- USB: 2USB3.0(@back) & 12USB2.0/1.1 (8@board, 4@back)
- Form Factor: uATX, 9.6"x 7.2" (24.4cm x 18.3cm)
In The Box
- 2 x SATA 6Gb/s cable
- 1x I/O shield
- 1 x CPU FAN
- User's manual
- Support CD: Drivers, ASUS PC Probe II, ASUS Update, Anti-virus software (OEM version)
Only £109.99 inc VAT.
ORDER NOW
Specifications
- 1x PCI slot
- 1x USB 3.0 port
- Gigabit LAN
ORDER NOW
Specification
ORDER NOW
Specifications
- ITX
ORDER NOW
Key specification
In The Box
- 1x I/O shield
- 1 x CPU FAN
- User's manual
ORDER NOW
