The New Cases Gallery
Build log HERE
What fans did u use, im looking for some red led fans for my new build
Aye it's definitely on the large side, in fact instead of mounting the cooler on to the motherboard, it was the other way round :D Had to set the cooler upside down and mount the motherboard on top. :p
LOL .... bit of a monster huh !
The CPU temperature must be really low? what temperatures do you get with that setup on the BeQuiet?
That thought crossed my mind as well, how efficient is that thing ?
I'm also assuming that the limitation might be the ability of a given case to ge the hot air out !
Looks a nice build antonusklesk, Clean build and yea still looks good in that case.'
Ive decided to Give my PC-A77 case a paint job and the weekend, Black interior looks soooo much better, pics will be posted soon.
Cheers, the longest part of the build was getting the rear side-panel back on!
Good cable routing in the case other than the fact that my 24-pin cable is just too fat and there's not quite enough room behind the mobo tray, meaning that back there it is seriously messy!
