gtx 460 vs radeon 6850
The HD6850 1GB and GTX460 1GB are very similar in performance although the HD6850 1GB has much lower power consumption:
http://www.anandtech.com/show/4002/amd-radeon-hd-6850-overclocking-roundup-asus-xfx-msi
These two HD6850 1GB cards have got good reviews:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-241-AS&groupid=701&catid=56&subcat=1866
http://www.overclockers.co.uk/showproduct.php?prodid=GX-115-MS&groupid=701&catid=56&subcat=1866
The MSI card can be had for around £140 delivered if you shop around.
Too late, its there for the whole world to see:p
That's fine, it's what I get for being half asleep when I post :D
They're both similar in performance, just depends if you like ATI or Nvidia OP, or to an extent, which you can get cheaper.
Oh dear http://forums.nvidia.com/index.php?showtopic=187401
Not seen that before.
Seems like others are having problems as well. :(
Yes they are.
I'm one of them (even get quoted in the first post).
I would think very carefully before buying a GTX460. Nvidia are supposed to be "onto" this now, but they took their time, and there is still no solution.
I will say though, that my current Gigabyte GTX460 OC 1Gb is working OK in my current system, performs well and is very quiet. I still have a bad feeling about it though.
Yes they are.
Thanks for the heads up! My problem is at least making sense.... or i know i'm not alone.
