Urgent Help (oc staff) 2 hard drives fail in a week
19 Dec 2010
Teeside
Help, Ive just built a sandy bridge system based on an Asus p67p8 EVO motherboard.
i2600k , g.skill ripjaw 4gb sany bridge compatible from here.
i installed 2 x 1TB samsung spinpoints in Raid 0.
2 days after install i get a red warning on one of the drives on boot up, a day later it failed and just kept clicking.
I have sent the drive back to overclockers and received new drive.
2 hours after re installing everything, this time on the 6gb ports as recommended by this latest recall madness, one of the drives is again showing the red error message on boot up.
I ran hdtune to check for errors and one red block showed up
i have run scandisk which finds erros which it tried to fix, however after rebooting and using hdtune again there is still a red block that is damaged.
The PC is just locking up all the time and its about to fail again.
what the hell do i do now???
can i rma another drive this soon, is it the p67 chipset even though I'm using the 6gbps ports.
I don't know what to do, after 2 weeks I'm still not able to use my PC correctly and this is turning out to be a nightmare.
Tried new cables, everything is seated correctly, psu is more than powerfull enough to run system (750w)
please help i just dont know what to do, im sure the drive is about to fail again
you think i should ask for another rma ???
im having trouble getting on here to post as the pc is just freezing every 5 minutes
ok i posted in the ocuk rma queries section.
i havent had a hard drive fail in 15 years and now two in a week?
If it is showing errors, then you are going to have to unfortunately.
To be fair, I would return it, add another £45 in the mix and get and SSD for your boot drive and use a single F3 for storage.
Might be something else causing it though. I will let some of the others assist.
Dodgy batch maybe? RMA and ask for a WD or seagate and see if it still does it.
Also how did the drives arrive to you? I ordered 2 drives from OCuk which were poorly packaged and as such one was DOA.
taken from the sticky at the top of the page
For you own interest, it’s a not a good idea to post any OcUK shop queries relating to pre or post orders, returns and technical queries. Please be aware that shop staff do not browse the forum looking for customer enquiries and your correspondence may be missed.
Instead, OcUK provides various convenient methods for contacting the shop and it’s suggested you use these:
Customer Services Forum
OcUK provides a Customer Services forum for OcUK customers only (forum membership required) which contain the following sub-forums:
Pre Sales Enquiries
Post your pre sales enquires in here. Please include the stock number and description where possible.
Order Queries
Post your Order enquires in here. Please include your Order Number in your opening post
RMA/Return and Technical Queries.
Post your RMA/Return & Technical queries on here. Please include your Order Number or RMA Number in your opening post
Posts in all the above sub-forums are only visible by those that make them and OcUK Staff, who are members of the moderating team so your privacy is assured.
A member of the OcUk Customer services team will endeavour to turnaround your query in due course.
Webnote
Alternatively, you can use OcUK's Webnote system to contact us about pre-sales, order and return queries. You'll receive a reply by email.
Telephone
Talking still works:
Sales - UK 0871 910 910 1
Sales - International +44 871 910 910 1
Support - UK 0871 910 910 2
Support - International +44 871 910 910 2
Systems Support - UK 0871 910 910 3 (Mon-Fri only)
Systems Support - International +44 871 910 910 3 (Mon-Fri only)
Calls from UK landlines cost 10 pence per minute. Call charges from mobiles and international numbers may cost more.
Lines open 8.30am to 5.30pm Monday to Friday and 9.00am to 5.00pm Saturday (except systems support)
Fax
From the UK 0871 910 910 4
International +44 871 910 910 4
Address
Overclockers UK (Esnet Ltd)
4 Axis
Millennium Way
High Carr Business Park
Newcastle-under-Lyme
Staffordshire ST5 7UF
United Kingdom
So, it’s all there for you.
They were in a cardboard box inside two plastic boxes, wrapped in bubble rap.
just cant believe two drives can fail after 15 years without a single falure.
Edit i have posted in the rma section, i guess il have to seperate the raid and see which drive has failed again :-(
You're sure it's the hard drive and not the SATA ports on the motherboard? Sandy Bridge motherboard SATA has a known problem and Intel have halted shipments for now.
hard drives fail sometimes.
this is a fact of life, two in quick succession is just adhering to the law of averages.
i have posted in your support thread already, i need your order number posted there so i can actually help you.
These things happen.
I've had no failures in many years and then recently found a drive showing some serious errors in the SMART info. Bought a replacement to cover the return time and the new drive failed in two days! Now all replaced and working fine.
well lets hope its third time lucky im sick of setting up windows.
im starting to doubt my own ability to setup a pc, after 15 years building my own.
enough to drive a man mad
Kinda feel your pain on this one! Ok its only one drive but it failed right out of the box and to make matters worse I am a bit concerned as to where ocuk sourced the drives in the first place. I was forced to return it to ocuk not samsung as they would not honour the warranty :rolleyes:
I once had an error showing up in the raid array but the drive worked with out any problems
ask overclockers to supply u a drive that was manufactured in 2011 as then u are sure to get the latest controllor chip and firmware
i had a WD green 1.5 TB burn out and got sent a drive that was manufactured months before i had purchesd the drive i soon sent it back and got one that was manufactured much later on
I had a similar problem as well.
Had my original Spinpoint F1 fail on me, so sent it back to Overclockers.
When the replacement arrived (different build date and batch number) it was making such a loud scratching noise that the guy at Overclockers could hear it over the phone!
So after another RMA, the third drive has so far proved reliable (touch wood).
In my experience, drives tend to fail straight away or work for a long time. :)
Are you sure the HD's you received were new? I got one from OCUK not long back which was sold as a "new/oem". Turned out it had been pulled from an Iomega external storage unit and had been used for over 200hrs! Tried to RMA it but Overclockers refused......
That's not a reason for RMAing the drive (RMAs are used for faulty products).
What you should have asked for is a product that matches the discription (new) as per the Sale of Goods act.
But enough of that - if you've got a problem with OCs service the best method of complaining is to do it privately via the web-note or customer service forum. Complaining in a "public" thread rarely gets you anywhere..
