Gaming: Dell 3007WFP HC 30" LCD
Yes, that's the best 30 inch for gaming Dell have made mainly due to it's decent input lag however you should consider the HP ZR30w aswell which has even less or the Hazro 30 inch on here which has a bit more than the HP yet around the same image quality.
I would say a 6970 is enough for majority of games but if you adding high AA then you may want to crossfire them though i expect it to be fine at that res with about 4xmsaa which is all you need really for that res.
