Quick reply thanks, So not worth getting either of the 69's then.
What would be worthwhile then Nvidia card maybe ?
TBH, you have a really really good setup. If you must upgrade, then two 560's or 570's. A 580 overclocked would be good too. What exctly are you hoping to achieve out of upgrading?
What is your budget aswell?
EDIT: just saw that you only have 1 5850. I would get another. best value for money IMO
Mate, just a quick warning that your sig is too long. I would change it before the mods doThanks so nothing to do then, might build another rig or go watercooled![]()
A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text. If no images are used then up to 4 consecutive lines of normal or smaller text is permitted. Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels.
