*****MSI ATI Radeon HD 6950 Rev1 2048MB GDDR5 ONLY £197.99 Inc. VAT!*****
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
**SPECIAL PRE-ORDER PRICE ONLY**
MSI ATI Radeon HD 6950 2048MB GDDR5 PCI-Express Graphics Card @ £197.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Revision 1: Flashable to 6970
- Core Clock: 800MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required
- 450W minimum PSU recommended
- Card Dimension(mm) 275*110*38mm
- Warranty: 2 Years
Was [£219.99] Inc. VAT
Only £197.99 inc VAT.
ORDER NOW
This is the lowest price by far in the UK on a top quality branded ATi Radeon HD 6950 with 2GB of memory. These are also revision 1 which means they are flashable.
I am doing this price *ONLY* until stock arrives or until we've sold the first 200 units. So ensure you get one at this price I suggest you order before Monday. :)
resist it, it is easy, just don't buy it!!! I am not going to, because I don't need to. All the games I play normally play at 60 fps+ :)
Gibbo - any idea how loud these are? I'm looking to upgrade from a 4870x2 as I find it way too loud under load..any idea how these cope?
Reference cooler so very quiet when just running normal 2D and still quiet when gaming, only get loud when OC'd or in a poorly ventilated case or when ambient temps are high as in Summer.
That's good to hear, read something that said they where only a few dB quieter than a 480... Found this hard to believe :p
As Gibbo has said these are much quieter than a 4870x2. They are not completely silent when overclocked/unlocked but are not a jet engine either! :)
What are you doing! This is like the 3rd 6950 deal in as many weeks how can i resist.
Would it matter if I already have a OcUK/Powercolor one and mix it with the MSI for xfire?
What sort of date do you expect them to arrive in stock?
I've heard of people mixing 6950's into a successful crossfire, not sure though. if not maybe if you both flash them with the same bios?
