ended up getting windows 7 home premium 64 bit for a steal on a popular online auction site...... thats if it ever turns up
Check box and labels to determine if it looks genuine before opening.
I hope its not from the same guy I bought mine from. It was supposed to be sent first class recorded a week ago and it has not arrived yet! Strangely enough he can't supply the recorded delivery number so I will be contacting the auction site for a refund very soon![]()
one major thing to be careful of is *popular online auction site* sellers selling MSDN test keys, they will work for install and seem to activate ok, but they are really for MSDN developers, and will de-activate, requiring you to obtain a new key from MSDN, after 3 months, by which time of course, the seller has moved to a new *auction site* account leaving you no recourse.
there is a way to tell immediately, by comparing the 3 digit section of the product ID (different to product key). this can be found by going to 'computer' and clicking 'system properties' at the top
some info here, although I can't find the list of what 3 digit sections would confirm the MSDN theory
http://social.answers.microsoft.com...l/thread/90be52f6-5a97-4df9-b4ee-b11bd4462267
[hope there are no competitor links in the thread, I'm just trying to help webb and can't be bothered to read the whole thing again]
When TrojanWhore linked to an external forum thread it was possible there were links in that thread to a Competitor of OcUK, such a link breaks the OcUK Forum rules, so he was hoping to avoid sanction with his comment. Of course he should have run through the thread to check, ho hum!Thanks TrojanWhorePS whats competitor links in thread mean ?
Got my windows 7 home premium just the one Hologram disk 64 bit with product key came inside another box that says its a OEM System Builders Pack Intended for system builders only ? but if it activates OK, i built this system![]()
If there is a free partition for you to install to, then yes you can install Windows 7 to the same HDD as XP. No other partitions will be affected.not tried yet, want to install to a partition on a disk that also has XP Pro 32 bit in a separate partition, can this be done ? also on this same disk is my saved files in a nother separate partition all partition are NTFS
Windows 7 is no different. Windows 7 will also create a boot loader, so you can choose which OS to boot on start up. Though separate HDDs is my preferred method of dual booting. I just switch boot order if I need to change OS. Though these days I have VMs and a work laptop if I need to use a different OS to 7.don't wont to loose my XP Pro or saved files, all previous windows let u decide where to install a operating system is this true for win 7 ? and will win XP still boot when win 7 takes over the MBR or am i just best of installing to separate HDD ?
My idea was to have three partitions first 200GB win 7 64 bit, second 100GB XP Pro 32 bit, third storage app 630GB, i was then hoping to raid that drive with another 1TB drive ?
It doesn't matter one jot what the other OS is when you dual boot. It could be Linux, FreeBSD or MSDOS. Your OS does not share any files with any other OS.but unsure if would work cos of 32 bit and 64 bit on same HDD plus cant raid at the moment anyway until i get new board
any advise help welcome Webb
You are only a system builder if you sell the system. Building it for yourself doesn't count. So strictly speaking you are not legitimately using your copy of Windows 7!
I also wouldn't bother with RAID unless you have a dedicated RAID card. Software RAID sucks in comparison and is a nightmare to sort out if you ever change boards in future.
Creating a RAID would destroy all the data. So you would be wasting your time installing anything.
