All my shortcuts are blank and non-functional
8 Nov 2002
Kent
http://www.t55.net/forum/viewtopic.php?f=4&t=911
I noticed another post for help is unanswered for over a week and the board appears to be unmodderated according to the spam. I believe I got a link to this program via warp2search.com (which I trust) and one of its "selling" points was that it was approved by microsoft. I'm not sure about that now.
If anything this is a warning not to use this clumsy program especially its registry altering functions.
Reasons why users uninstall:
http://www.t55.net/forum/viewtopic.php?f=2&t=13
Unfortunately I did not realise I had no restore point before I started mucking about with that POS optimiser program.
Well tbh, if I can't find a solution I'll just reinstall. I have win xp sp3, win 7 utltimate and this win 7 ultimate sp1 installed. I don't make partitions big enough to accomodate service packs extracting on the OS partition.
I'm just limping along atm, can open programs with windows key + r and task manager and they hold a list of recently opened programs. Ouh also windows key + e works, just read about that searching for a solution.
That crap program killed all my sendto list. I will have to look up where the sendto folder is again. Edit: no the sendto shortcuts are there but same problem.
LMAO
You have been permanently banned from this board.
Please contact the Board Administrator for more information.
A ban has been issued on your IP address.
For asking for help
Ok just email the guy back after he sent reg file to fix it and told him what I thought about his program. It looks good atm back to normal. I would have probably been ok with it but getting banned from that forum is ridiculous. All I said was that I suggested a user uninstall this program since he got no reply for help in 7 days, and there was spammy chain letter type posts on the board.
I tried two programs before the registry file:
Iolo System Mechanic
had a fix shortcuts routine which didnt fix my shortcuts, I think it was an answer in a yahoo question.
TweakNow power pack 2011 also did not fix it only the registry files.
When will people learn that there really isn't any need for any of these "cleaner" type programs.
CCleaner, spybot s&d, spyware blaster, and malware-bytes are programs I use which don't cause problems. Just because one "car" is unreliable you can't generalise.
Professional and easy-to-use are what T55 WinMate pursuit of.
Yes - deleting old temporary files and scanning for malware are good ideas. Letting a program mess with your registry when its website is mostly nonsensical and it has no reviews from reputable tech sites is definitely not a good idea, though.
