*****MSI ATI Radeon HD 6950 Rev1 2048MB GDDR5 ONLY £197.99 Inc. VAT!*****
Yep seems it can't be flashed - bah...anyone succeeded in fitting other graphics coolers to 6950s?
Yes, I have.
AC xtreme 5870, You only need a couple of extra heatsinks for the vrm as the 5870 vrm's are different to the 6950's, and your good to go.
50c max in Kombuster @1g on the core!
Really trying hard not to buy another for xfire.:eek:
Hi there
OK MSI seem to use very fast couriers, they have arrived, but I shall honor this special price until Monday!
I can't find reviews for this card on the web. Very strange!
I found this though > http://i4memory.com/f18/msi-radeon-6950-6970-review-28152/ which is someones forum review, also mentioning the cards flashing.
Anyone know if these come with the metal back plate that the reference coolers use?
Im pretty sure they do. I just looked at an un-boxing on youtube and they show the back plate :)
Regards Ryan
Any plan to stock Gigabyte releases of this card? The only thing turning me off MSI and the other brands are their European return bases.
Regards Ryan
Thanks Ryan! Just found it :D
Mine should be arriving tommorow (fingers crossed & touch wood) so I shall confirm whether it has one or not :D
Cheers, John
On "Today Only" today for £199.98.
Good time for anyone wanting to go crossfire, unlock shaders and get 6990 matching performance then now's the time! :)
I've got a Revision B 6950 and the 6970 bios works no problem, although I just use the Shader Unlock, on stock volts 1.1v clocked up to 6970 speeds.
