Time to lean on the wisdom of you good folk on these forums once again.
Basically put my new build together last night but with numerous problems. New kit included:
Asus P8P67 mobo
Corsair H50 water cooling kit (first venture into watercooling)
Intel 2500k CPU @ 3.3Ghz
Momentus hybrid drive
2 x 4 gig sticks of G Skill 1600 ram
Old bits include
Case - Coolermaster 830 Stacker
GTX 570 graphics
Enermax 620 Watt modular PSU
1st problem: new HDD (Momentus Hybrid) doesn't fit in my drive bays and I no longer have any spare attachments (such as floppy drive bay). Can some type of adapter be bought here or elsewhere? Therefore didn't use this drive and instead reverted to a new Seagate mechanical drive.
2nd and by far the more worrying problem is the pc now (often) needs several attempts to boot up - often requiring a CMOS reset (all bios at default). The pc will often fire up briefly (3-5 seconds), then shut down and fire up without touching it again, only to shut down a few seconds later.
Tried swapping out ram modules in all manner of configurations but wondering whether I have a suspect board? Should also say I'm using my previous sata leads but wouldn't have thought these would cause issues (can try new ones if folk think thats worth a try).
Anybody else suffer any of these symptoms with this type of set up?
Cheers
Asus P8P67 mobo
Old bits include
GTX 570 graphics
Cheers
