It's an american/european plug, you'll need an adapter. Also, check to make sure the power supply has the red switch on the back to 230V (if it has one, if not, it'll be fine).
. That's a bit cheap of them and probably against some kind of regulation, as it encourages people to do the 'two into three' trick
.Normally continental / US spec hardware comes with the adaptor when sold into the UK. That's a bit cheap of them and probably against some kind of regulation, as it encourages people to do the 'two into three' trick
Maybe they just forgot to put an adaptor in the box!
Pretty annoying that it doesn't come with a UK compatible plug though.
Does it fit in the socket? Just run it without the earth pin. Switch the power off, stick something plastic into the earth pin, stick the two-pronged plug into the wall socket. I used to run loads of stuff like this when I moved back from Germany and never bothered re-wiring everything.
I think I'll go get a new lead rather than doing this...
ROFL yea dont worry about earthing your whole PC its easily replaced when it blows up
worst advice ive ever seen on this forum
