Mass conversion of ripped DVD's (Ones I own)
23 May 2006
I had set up a HTPC, burnt about 1tb of them to a hard disc at 100% quality/size for use on my HTPC.
Now I have decided to go down the NAS route, with WD TV as the front end.
Is there a way to mass convert my rips into a smaller file size that still retains quality, and is usable by the WDTV. ideally in batch fasion.
Need to do this as I don't want to have to buy more HD's
Thanks in advance
Not played much with handbrake, whats best settings for files if I want to put them on a NAS, then stream them to WD TV via an amp on to a 42 inch plasma?
Handbrake is a pile of turd compared to tools like MeGui I'm sorry to say.
It's recommended a lot simply because it's easy to use.
So you can't /thread with Handbrake alone.
I think you will find that i did though . . . . :p
Nothing wrong with it at all.
I know, not arguing that but it still says you have a right to make a copy.
Contradictory law is contradictory :(
I would also like to know the answer to this question.
HOWEVER, its not for film DVD's its for a few WEDDING DVD's that I own.
I've used MakeMKV and its a lot quicker than Handbrake but does it produce better rips?
Handbrake encodes, makemkv transcodes. MakeMKV just puts the file in an MKV container, so a DVDrip will be the MPG2, AC3/DTS and subtitle streams in an MKV file. Handbrake will take those streams, encode them according to the settings/codecs specified and put it in an MP4 or MKV container.
MPG2 is a fairly inefficient format, encoding tp x264 gives much smaller files without perceivable loss in quality.
That said, the main movie on a DVD is usually 3-6gb (taking account of extras, foreign audio etc) and with the price of HDDs, you might as well not bother unless you have a huge collection.
BD on the other hand :eek: I've found around 8gb with AC3/DTS and 10gb with TrueHD/DTS-HD at 1080p is barely different IMO, though ymmv and obviously it depends on your equipment etc.
