STS-133 Shuttle Mission to the International Space Station Launches Thursday 21:50 GMT
simulatorman, why is it that there aren't heat tiles on the whole of the orbiter, only the underside? I know the underside gets most of the heat plasma build up on the way back through earth's atmosphere, but doesn't the rest of the body get an enormous amount of heat too?
The whole shuttle is covered with varying degrees of protection. Explained here:
http://depts.washington.edu/matseed...e/Space Shuttle Tiles/Space Shuttle Tiles.htm
More:
http://en.wikipedia.org/wiki/Space_Shuttle_thermal_protection_system
Obviously it is held by that large protective cover for the large portion of its stay at the launch pad, not sure on the name of it though.
The Rotating Service Structure is mostly for access and protection, not support. Prior to tanking, almost all the weight is the full Solid Rocket Boosters (571,000 kg each). The orbiter, even full, is a tenth of that, and the ET even less. All this means that the RSS would do more harm than good if it tried to offer any support.
Another question :D The robotic arms of the shuttle and the ISS will work together to install the first payload to the ISS. So, since there's no EVA today, presumably this piece of equipment must just get slotted into place by the arms, with no nuts and bolts to screw in?
Before anyone dares mention screws - absolutely not! You don't want spacewalkers going anywhere near screws. They'd go everywhere. They had to build all kind of special gizmos to stop screws getting loose when they were servicing Hubble. That was full of screws that were never meant to be taken out - except they had to be taken out.
Bolts? Yes. But in this case, it'll either be a motor-driven capture claw, or motor-driven bolts, or both. Power and data will be mechanically connected too.
Cool, thanks for the info Berserker.
Cargo transfer will be on Flight Day 4
Spacewalk 1 on FD 5
PMM installed on FD 6
Spacewalk 2 on FD 7
The two spacewalks:
You can find more into in the mission pack links in first post.
Shot from an american student science project, cost about $50-60 probably (£30-40), shows the vapour trail from Discovery entering orbit.
I'm going to look out for discovery tonight. http://spaceweather.com/flybys/
For my town on 27th feb:
ISS - Discovery - rise time: 07:02:12 pm - direction:W - transit time :07:04:39 - elevation: 88° - magnitude: -4.0 (very bright)
Not sure which way is west though, guess I'll swing around all directions, there's a 2 minute window before it disappears.
You are not sure which way is West? Blimey! Do you at least know which direction your garden/back of the home is facing?
Google maps will help you of not!
Yes I'll check with google maps, good idea. Don't know which direction my garden faces :o
Seems the front of my house is directly west facing so I'll just look straight ahead and upwards.
