Help.. I'm building my first Custom system
23 Feb 2011
Hello all,
I am looking to build my first custom PC. I have a budget of about £600 not including case and PS.
Can anyone help of give me some ideas. Would prefer an AMD system and fairly high powered to keep up in the gaming aspect of things.
Thanks in advance..
Asus ATI Radeon HD 6950 OC 2048MB GDDR5 PCI-Express Graphics Card £213.59
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £191.99
Asus P8P67 Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge)
£124.99
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD105SI)
£38.98
OCZ Platinum 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Ultra Low Voltage Dual Channel Kit (OCZ3P1600C9ELV4GK) £29.99
Samsung SH-S223C/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM
£13.99
Sub Total : £511.27
Shipping : £10.00
VAT : £104.25
Total : £625.52
Better for gaming than any amd system I can think of, but someone will probably fill you in
Although PS has been shipped yet so i can change my mind if needs must..
Do it because the one you selected is a pile of crap. I am getting fed up with saying this but, never, ever skimp on a psu. It is not the place to save money. It is the single most important component in a pc. Cheap ones are a false investment and you will nearly always end up replacing it and the components it took out when it fails/blows up. Cheap psu's will not even get close to being able to deliver their stated outputs, have weak/unstable rails, are innefficient and are built from cheap and nasty components.
Buy a decent brand one from the likes of Enermax, XFX, Be-Quiet, Corsair etc.
At the moment it seems intel are leading the way (ignoring the chipset cockup)
AMD are releasing a new toy soon, so anyones game really.
Sandy bridge Intel is hugely faster than any of the current AMD chips. If you are building a new rig now, that's got to be the way to go.
Depends whether OP wants to go through the hassle of the return procedure though
OP won't need to return the board if they get SATA 3 drives and only use ports 0 and 1 for SATA 2. It's only 2-6 SATA 2 that are effected.
EDIT: In fact all of the 6 gb/s ports for sata 3 are unaffected. I'm right in saying this i think?
Yeah i think so, just thought I'd say if OP doesn't like the lack of the abiltity to add devices to the other ports should he wish to in the future. I thought it was that all 3gbps ports were affected, and not the 6gb/s
