Hi,
Just thought I'd ask as I know there are a few plumbers on here. My mum is having trouble with her heating system. The radiators will turn on when just the hot water is selected.
From a quick google it would seem that the Mid position motorised valve has packed in? This looks like it would be very easy for me to replace.
The problem is that she wants to swap the old gas boiler/emersion heater for a combi-boiler at some point in the future. Would the motorised valve still be needed in the new system? As i don't want to waste £60 buying one, only to scrap it in a couple of years.
Also I think I might swap out the pump at the same time as that is going on for 15 years old now. Would the pump be ok with the new system, or do combi-boiler systems not use a pump?
This is the motorised valve: http://www.heatingcontrolsonline.co...a16793-midposition-motorised-valve-p-110.html
And the pump: http://www.heatingcontrolsonline.co.uk/circulating-pumps-myson-compact-cp53-domestic-pump-p-193.html
TIA
TIA
