Hi there
Well the MLR guys had an RR meet today at The Racing Line so decided to go along and run my car, nothing has been changed since it was at Powerstation, so one would expect similar results:-
Here is the Powerstation result on what was a very cold day:-
Highlights were corrected engine power at crank of 397BHP, 299BHP at the wheels and circa 355lb/ft. All I questioned was what appeared to be a low torque figure as the BHP seems about right.
Here are todays results from the Racing Line, car the same, though it was warmer.
Crank flywheel of 390BHP, power at the wheels of 305BHP and torque seems to be where it should be at circa 380lb/ft with a lovely power graph, infact it was said to be one of the best of day the on the X's.
This is a different dyno to what Powerstation uses but it still a two-contact patch dyno but is said to be very accurate for at the wheel figures.
Still good day out and the owner who specialises in tuning X's commented as to why FQ-360's make such good power with just an exhaust. Basically on the FQ-360 the ECU has a higher boost target set than what is achievable so when you let the car breathe the car comes closer to hitting this boost target and hence such good power increase of 30+ BHP from just an exhaust.
that said though,unless I'm googling wrong, My 12 litre 6pot diesel has (1549 lbf/ft.), your 2litre 4pot petrol currently puts out(343 lb/ft)
