he did not say it was a digital copy so what else do you want us to think ?
Why would you presume that it is a cracked copy?
There are loads of threads where people have asked how to burn a digital copy of windows 7, you only have to look.
Why are you doing that? Can't you just install Windows first?
tried it, it said it wasnt a proper boot device
hmm, i think i'll wait till the weekend when my dad is around. i have literally no clue what im doingMake sure you've set the CD/DVD drive to boot first in the BIOS.
thanks, but im just leaving it till dad is aroundWhen you power on the computer, as it's booting up and posting, there should be information about how to access the BIOS. Normally it's either pressing the delete or F2 key on the keyboard. When you're in BIOS there should be a "Boot" menu. Use the arrow keys to navigate to that. When you get to that part of the menu, you should be able to set the boot device priority. Since you have Windows on CD/DVD, you want to make the CD/DVD drive first in the boot priority. Then the HDD second and any other methods (such as USB or whatever) last.
Then you exit BIOS and choose to save the options. The computer will restart, so put your CD/DVD in the drive and it should boot from that first.
