P67A-GD65 (1.8b13):
http://91.121.148.119/downloads/BIOS/E7681IMS.18D
- Update FITC and ME FW to 7.0.4.1197.
- Fixed EUP 2013 cannot disabled.
- Add Backup NVRAM block when MFlash/F75221 update BIOS (if FAULT_TOLERANT_NVRAM_UPDATE= ON)
- Fix CPU status in CPU SPEC always show Unlock
- Update GPower module V0.08/V0.09
---- Follow H/W recommend to modify GPower default setting.(CPU Phase default:Intel SVID)
---- Fix no full phase issue.
---- Add token "Patch_VCore_Step".
- Update MSI-P67MRC-V1.40/V1.50
---- Add Low Memory solution.
---- Update Memory Initialize Reference Code to version:1.1.1.01
- Modify setup Copyright string (Copyright (C) 2011)
- Update 4.6.4_Intel_CPT_038
- Update SandyBridge_A;4.6.4_Intel_SNB_035
- Modify the way of getting BIOS ver data in setup and Post.
- Fill in the ACPI table's OEMID&OEM TABLE ID with the SLIC's.
- Fix current cpu ratio show incorrect when adjust cpu ratio in OS enabled.
