Which B3 stepping Board ?
at your budget you can get the Asrock extreme 4 which seems to be a very good motherboard especially for the price it goes for.
If you can stretch that a bit you can't go wrong with the P8P67 pro
There no B3 motherboards instock anywhere yet...
But i have seen some places listing the new asus B3 motherboards for pre-order
Thanks guys. Will the new B3 boards have the same model numbers except be B3. What is the difference between the old B2 and B3 ?
All you need to know is that B3 is the updated revision of the onboard chipset, previous version had tha sata 2 issue.
