Hello.
I've finally finished Dead Space, so loaded up Dead Space 2 today. I had zero problems with Dead Space but I'm getting some funnies with the new game. In-game cut scenes are all blurred and colours are blending into one.
Now I fixed that by disabling "Blur" in the in-game menu. (I wondered why I missed the first cut scene and suddenly was in-game running around... I thought I had nodded off. lol.
Second problem now though, when enemies grab you and you hit "E" the screen goes bright yellow! I can't see anything except the letter "E". Once I bash them off, the game goes normal.
Third problem, the store. The animation for the screen unfolding and for fitting your suit does not work. I can hear the sound in the background, but I have a still image on screen. Tapping "ESC" does nothing, but pressing "Pause" does; and I get a slide show if I keep pausing/un-pausing the game.
I am running v11.2 of ATi's cats on a 6950 GPU (unlocked to 6970).
Do I perhaps need to disable something else in the options to fix these issues? I've managed to get to chapter 2 but do not want to go further as this is spoiling the game play.
Thanks for any help!
