http://www.overclockers.co.uk/showproduct.php?prodid=GX-128-GW&groupid=701&catid=1914&subcat=1830
Or the Msi 5850 when it is £135
Surely it'd be the MSI HD5850, that fiver over the budget is well worth paying?
I would go for the 5850 personally, It would probably last you the longest.
Yep, forgot about that one. That's the one to go for.![]()
Well, I don't think xfire 6850 beating xfire 5850 by just 1fps is really worth mentioning...5850 would be quite a bit faster than 6850 and GTX460 as a single card here and now.If future Xfire is an option then the 6850 beats the 5850 for me due to the better scaling the 6 series offers, if its just a single card solution youre looking at then a 5850 for just over or 460 for just under
In the end I ordered a 6870 for £155 so apart from buying second hand I think I got a pretty good bang for buck deal![]()
Can I ask which 6870 you ordered?
