So I've just splashed out and treated myself to a 6970 http://www.overclockers.co.uk/showproduct.php?prodid=GX-191-XF&tool=3
I am for the most part very pleased the performance is pretty awesome.
What I'm not so keen about is the noise this thing makes and to a lesser extent the heat. At idle it sits with the fan at around 30% and temps at 55 degrees. Im a stickler for noise and everything else in my system is optimised for quietness. At 30% the fan is fairly quiet but crank it to 50% and its annoyingly loud crank it to 100% and it sounds like there's a jet engine running at full thrust inside my PC case.
I've had a look for aftermarket coolers and have come across this http://www.hardwareoverclock.com/Al...D6970_Arctic_Cooling_Accelero_Xtreme_Plus.htm has any tried one? Are they good and are they quiet?
I am struggling to find any other alternatives does anyone have any other suggestions that would fit a 6970?
