Ordering in the next 25 minutes
I have just purchased the P8P67-M, if you want to OC your sandy don't get this board, I stupidly thought the BIOS would be as per the P8P67 ATX board but they are not, you have no access to vcore adjustment so very limited OC ability.
err...? I did not pick the microatx
Look at his updated spec.
OMG SHOULD I PUSH BUILD????
t Name Price Qty Line Total
Asus GeForce GTX 480 1536MB GDDR5 PCI-Express Graphics Card with Far Cry 2 £161.65 1 £161.65
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM £141.66 1 £141.66
Asus P8P67 PRO Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION ** £124.99 1 £124.99
Samsung P2370 23" Widescreen LCD Monitor - Glossy Black £99.99 1 £99.99
Crucial RealSSD C300 64GB 2.5" SATA 6Gb/s Solid State Hard Drive (CTFDDAC064MAG-1G1) £79.99 1 £79.99
Coolermaster CM-690 II Advanced Dominator Case - All White £68.08 1 £68.08
Microsoft Windows 7 Home Premium 64-Bit - OEM (GFC-00599) £66.66 1 £66.66
Creative T6160 5.1 Speaker System (51MF4105AA003) £44.99 1 £44.99
OCZ StealthXStream 2 600W Power Supply £39.99 1 £39.99
Razer DeathAdder Respawn 3500dpi Xtreme Precision Gaming Mouse and FREE Boogie Bug AimB.Pad XL Gaming Mouse Surface £38.81 1 £38.81
Razer Arctosa Keyboard - Silver £33.32 1 £33.32
Akasa AK-CCX-4002HP Venom CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/AM2/AM3) £30.82 1 £30.82
OCZ Special OPS 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (OCZ3SOE1600LV4GK) £27.99 1 £27.99
Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache - OEM (ST3500418AS) £23.32 1 £23.32
Samsung SH-S223C/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM £9.99 1 £9.99
Arctic Silver 5 Thermal Compound (3.5g) £5.61 1 £5.61
Sub Total : £997.86
DPD Next Day Parcel Saturday Shipping : £30.05
VAT is being charged at 20.00% VAT : £205.58
Total: £1233.49
No.
Save £11 and get the MSI P67A-GD55
Does everything the PRO does for cheaper and at the loss of a few expansion slots which you'll never use and a few more USB slots, which you'll never use :p
Looks fine mate, I'd just swap the HDD for an F3, and get rid of those awful speakers (coming from an audiophile) but if you don't mind sacrificing sound quality for price then sure, go for it.
E: Oh, and better SSD http://www.overclockers.co.uk/showproduct.php?prodid=HD-047-OC&groupid=701&catid=14&subcat=910
K i swapped out the SSD
any reason for HD swap bud?
Also are you sure about the speakers for playing music?
No.
thats not a b3 revision if i am correct..
Personal preference really, but I'm quite sure I know a guy who bought a set of those (or a similar set up/price range) sent them back because he didn't like the sound quality.
If music is your main usage then 5.1 isn't really ideal anyway.
E: I'm used to demo'ing every piece of home audio equipment I buy anyway, maybe I'm raising the bar too high...
thanks for your opinion.
What do you think of the rest?
No it's not. But I wouldn't say it matters tbh as you still have the warranty and MSI will replace it if anything happens.
Also TIM isn't needed.
Arctosa isn't much better than the X4 and is less likely to break ;)
Why the change to a slow SSD?
K I switched that puppy out. It saves me some dosh.
Anyway I can cut down the price a little more?
Get speakers from highstreet? Save you some cost on postage :p
I assume you removed TIM and swapped mobo and keyboard?
Could swap out the lite version of the case. You'd loose the hotswappable drive bay and a fan (front fans are also 120mm instead of 140mm).
Only other thing would be the mouse, but that's a very personal and subjective choice.
