Anyone up for a game now that the servers are sorted?
Sure, add me. Sully WOOF
Tom, Adler is now yours. Ask Killswitch which German players to get. Klose is probably the best to get now, always a bargain.
 Try to get Gomez too, rate him much more than Klose and about the same cost!
Try and get an in form Schmelzer for your LB as Germany don't have many decent LB's, Lahm for the RB or if you can't afford him go for Castro. I've got Metzelder and Mertesacker for my CB's but I would recommend either of those alongside Friedrich or Westermann because they are both good in the air and have a bit more pace than Metzelder and Mertesacker together.
Frings is a good budget CDM and for forwards on a budget I'd go for Klose and Helmes.
Thanks mate
Schmelzer was a fortune around 8K and Lahm was to so I think I'll have to skip them for now. I've got Castro, Metzelder(doesn't like the 4-1-2-1-2 formation though) and Friedrich so far.
Got Klose and Helmes upfront. Suggest any other cheap ones for LB, LM CAM and RM? (4-1-2-1-2 formation) Got about 3.7K to spend
Cheers
 It probably won't go for much more than 4,000. Schmelzer cost me 9,000 iirc.
 It probably won't go for much more than 4,000. Schmelzer cost me 9,000 iirc.Dont believe that.
To be honest you deserved the win and the speed of your team pretty much dominated my defence but 120th minute
