Hi all, well I was playing last nite and my xbox froze up and outputted some annyoying noise to the speakers. It also messes up the graphics on screen (hopefully you can see from the photo). I restarted then it worked for about 2 minutes then the same thing. Now it doesnt even boot.
I am aware that there are major issues with the older xbox's and have done a fair amount of research, but I cant find anyone describing my exact fault, and im just wondering if anyone has had the same issue as me, and if the method of re-applying the thermal transfer compound and re-fixing the heatsink has worked for them?
Cheers
Cheers
