Spec a decent case
9 Jan 2011
Right, i currently have the coolermaster elite 430 windowed.
It's a good case on a budget, but i reckon that if i ever want to crossfire down the line(i probably will) then it would be best to get something with a little more room, or at least better cable management.
I am looking at this
http://www.overclockers.co.uk/showproduct.php?prodid=CA-182-LL
Thoughts anyone?
i'll spend a max of £100 i think.
i currently have a 5850, which is fine at the moment, and will be for a while tbh, but when i do need a bit more, i will probably crossfire instead of getting a new card(i'm thinking of 6months- a year)
Also, i am going to get an AM3+ board with crossfire support when they come out, as my current board doesn't support crossfire.
any case suggestions would be helpful, especially if you have personal experience.
Cheers guys:)
Edit- Forgot to say, would prefer a side window, but not essential for a good case.
I currenltly only use 1 5.25" front bay, so two are probably needed at the most.
cheers for the suggestions.
How are the fans on the sniper noise-wise.
likewise the dominator, Ello Dave? what fans do you get with it? are they alright?
yeah, i do have a couple of 120mm fans i can stick in. the loudest thing in my whole set up at the moment is the case fan which came with it!
i think that puts me off the sniper, it has some fearsome looking fans
I like the looks of the Fractal cases, though I've never built in one. OCuK doesn't stock all the cases Fractal have released or made, so have a look at the Fractal Design website. I'm waiting until April to get myself the Define Mini for a server build.
the lancool dragon does not list the dimensions on teh spec. does anyone know?
One thing that i am looking for is space behind the mobo for the cables, as the 430 elite that i currently have does not really have any space for the cables, so even though i have a side window, which i like, it looks like a car crash. lol
Dabbles- Yeah, i have my pc on my desktop.
