Also look at the temps, theres a lot of room for manouvre with the Shaman in knocking the fan speed down further as it has such a massive cooling advantage.
The AC extreme has 3 fans cooling the whole length of the card including the vrm's, where as the Shaman is more centrally cooled towards the gpu. I'm not nocking the shaman, just pointing out the (imo) advantage the AC has, taking into account the other hotspots of the card.[timko];18598227 said:Yet another plus for the Shaman but the lack of bundled (or otherwise) VRM cooling is still a slight sticking point, for me at least on my 6950.
How's that MK13 working out for you?
So I've just splashed out and treated myself to a 6970 http://www.overclockers.co.uk/showproduct.php?prodid=GX-191-XF&tool=3
I am for the most part very pleased the performance is pretty awesome.
What I'm not so keen about is the noise this thing makes and to a lesser extent the heat. At idle it sits with the fan at around 30% and temps at 55 degrees. Im a stickler for noise and everything else in my system is optimised for quietness. At 30% the fan is fairly quiet but crank it to 50% and its annoyingly loud crank it to 100% and it sounds like there's a jet engine running at full thrust inside my PC case.
I've had a look for aftermarket coolers and have come across this http://www.hardwareoverclock.com/Al...D6970_Arctic_Cooling_Accelero_Xtreme_Plus.htm has any tried one? Are they good and are they quiet?
I am struggling to find any other alternatives does anyone have any other suggestions that would fit a 6970?
Link
I don't know about the zalman, but the Arctic Cooling Accelero Xtreme 5870 VGA Cooler fits if you get some heatsinks for the vrm's(or I suppose you could dremmel the vrm heatsink that comes with the AC) and 1 other part of the card with the heat pad(yellow circle). The chips on the 6950 next to the vrm's (pink line) are taller than the chips on a 5870.![]()
The AC Xtreme 5870 is superb at keeping the unlocked 6950 cool and very, very quiet. A good reason for using the AC over the zalman is the AC fans can be run through CCC or Afterburner. Where as the zalman irc are manually set.
Here is some temps for you, all running on automatic but GPUz lets you know what speed the fans are running at the time anyway.
Max 63 c @30% fan during BC2, max 58 c @28% fan during Heaven, Fallout New Vegas 53 c max @27% fan speed.
Skid, you beat me to it! I'm wondering if this fits the older cards like my 4870, then the mounting holes must be the same (unless there are multiple mounting kits with the Shaman?)
This might mean I can re use my older T-Rad on the 6970, £50 is a bit much at the moment for a new GPU cooler..
I'm guessing you remember the card dying from custom pc's review? That was the accelero xtreme plus. The accelero XTREME 5870 is the one I used, and the instructions clearly state to be very carefull with the chip that your talking about, touch it and the cards dead.Personally I'm steering clear of arctic cooling, first reviews of which one killed their 5870 as far as I could tell AC made no mention of the small bit top left in that picture you need to cool, I think they either didn't notice it or didn't mention it and several people killed their cards, now they've made heatsinks that need thermal adhesive to stick rather than design something simple that uses the two screw mounting holes which would be much safer.
Regarding heatsinks to cool the vrm and the chip in the circle, I used some 'Thermalright 8800 GT RAM /PWN DDR RAM heatsinks For HR-03Rev.A,V2'. They do the job nicely.
It wasn't a lack of cooling the chip that killed it, it was a case of anything metallic touching the chip and that was it gubbed.Yeah, thats the one, few other people killed theres, most of them still don't know the reason though I'm fairly sure its ignoring cooling that chip.
I agree, surely someone at AC must have borked a card by touching that chip when testing their coolers.Thing is at first they only had the "normal" one and just didn't mention anything about the chip, just puts me off at how lazy they were about it and frankly so inept.
I think it was custom pc that informed AC of the problem, but I wondered what happened to the poor folks that must have borked there cards.You only have to take off the stock sink and see frag tape on the stock heatsink to work out where needs cooling, a reviewer should know better, but a company should also NEVER list support and list where to cool and not mention one of the spots.
Tommybhoy, does that pack of sinks come with a few thinner ones, I couldn't quite tell due to the size of things around the vrm's but seemed like they'd need to be very thin.
Pretty poor show from them all so far, more so Prolimatech as the big sales pitch was how fantastic the cooler was because you could keep it and re-use it when a new card came out. I feel for you there mate.Its just a joke, I e-mail thermalright asking specific questions, get ignored, they list the 5870/50 being incompatible without appropriate VRM cooling but because they haven't got anything for the 6970/50 they say its just fine. Got a nonsense response from them after a couple weeks.
Zalman looks like it might fit, all they have to add to website is doesn't/does support 6970/50, not hard. Prolimatech are the most culpable as they actively went around saying how fantastic they'd be with support for new cards, the only thing they need is a very marginally different VRM sink and to make it available, but 3 months later and nothing, thats uber quick support, all while ignoring e-mails.
The 6970/50 should have been the SMOOTHEST move to 3rd party cooling ever, one minor vrm sink change and all available coolers could have supported the new cards incredibly easily.
Its just so frustrating, basically all these sinks offer between a 35-50C load temp drop, with silence, how can the stock sink be so bad.
I'm actually wondering if I can get away with cutting the middle of my Thermalright vrm cooler out, thing is some of them have two heatpipes but both on one side so you could just chop off the other part of the cooler. The one I got(the one that puts the sink infront of the cpu cooler), has the heatpipes essentially one running along both those yellow lines in the pic though the one on the left doesn't actually touch anything so is a rather daft/overkill design. I think if I can cut the middle out and its not touching that middle bit, then stick some frag tape on the resistors on the left that "might" work.
Out of interest what kind of VRM temps are you getting with just the ickle heatsinks on.
Its very irritating how not well its been covered, I've seen a couple reviews mention the VRM's on teh 6970/50 are more efficient, therefore run a heck of a lot cooler, but is that, 3C or 35C cooler, I have no idea how much cooling they want, keeping in mind I want to overvolt the card to hell and back![]()
