- 14 Nov 2002
- Under the Hill
Open ended spanners can have a bulge in the jaw that helps prevent rounding off nuts. Does anyone know a decent manufacturer who does these? I was looking at Britool but they don't appear to have them.
Also, does anyone have a combination spanner with a ratchet mechanism? If so, are they any good and what brand did you go for? My concern with any I have seen so far is that they're thicker than normal combination spanners by quite a bit. My budget is around £80 for about 10 spanners between 8mm and 20mm. I'll probably up the budget a bit if combis are worth it, however I may just get a 1/2 inch socket set and forgo the ratchets.
Thanks for any help ( I have already googled a lot)
P.S SnapOn are way over budget
