- 19 Jan 2006
Hi all you electrical wizards,
I've just installed new swithces and a new light in my room but am having a few problems with the wiring.
I installed the new switches which went fine, I assume, they are pictured below, I just copied the wiring from the original switches.
This is going to be a complete mess of an explanation as I really have no clue what I'm talking about to be frank so apologies in advance. The old light was a single pendant controlled by both switches, the new light is a bar of 4 spotlights which has a chocolate block style connector inside the housing.
I have 3 cables coming in, each with a red, black and earth. Two of the blacks are wired in to one input on the chocolate block, the earths are all together in the block, all the reds are together and in the chocolate block but don't actually connect to the wiring of the light and the other black is in the live socket of the chocolate block (I believe).
This all works internally in my room, I can switch the light on and offf with either the toggle switch or the pull switch, the problem I'm having affects the light on our landing. When the light is on in my room the switch for the landing light doesn't turn the landing light on or off, but when my room light is off the landing light works as normal and doesn't alter whether the light in my room is on or off.
Where do you think the problem lies?
