I've acquired an old projector - CTX EzPro 550.
It only has a component input on the projector so I bought a VGA - RCA adapter and then some coaxial cable to hook up the video channel to the projector.
The projector works fine on a DVD player with a yellow video input but I can't seem to get it to pick up signal from the computer.
I already have 2 monitors and even when just hooking up the projector on its own it still has no signal. There is a source button on the remote but the menu's inaccessible unless you've got an input and even then it can't be changed.
I'm led to believe from reading around that I need to force detection on the projector? I have an HD4870 1GB and in catalyst control centre I've forced detect TV but again can't seem to be able to get it to recognise the projector.
Not really sure where to go from here, I'm positive it isn't a cabling problem as they've been tested so I guess it needs to be configured. Any help would be appreciated
