finally got the rig working.
However getting errors with windows 7 64bit.
Keeps stopping applications and sometimes BSODS.
Ran memcheck and at overclocked settings it shows errors.
At stock settings memcheck shows no errors and windows runs like a charm. No more BSODS.
I am totally clueless on how to calculate RAM settings and just use the trial and error method. Can anyone help?
Upped fsb to 411
NB Voltage to 1.26
SB Voltage to 1.10
PCIE SATA 1.5
DRAM Voltage 2.2 (Kingston Hyper 4 x 2GB 1066)
FSB Term 1.2
CPU and PCIE Spread Spectrum - Disabled
Getting the following temps
On Load on Idle
Core 1 51 max 38 max
Core 2 40 max 35 max
Core 3 42 max 38 max
Core 4 47 max 38 max
I did change the DRAM frequency to 1069 (there is no 1066. there is a 1006 though)
and manually set the timings to 7-7-7-20 as per the sticker on the RAM
When I pushed the FSB up to about 470, I found that win 7 pro 64 threw a wobbly when booting and kept trying to run a repair. Dropped the FSB back to 411 and all was ok.
Can anyone advise pls?
Upped fsb to 411
NB Voltage to 1.26
SB Voltage to 1.10
PCIE SATA 1.5
FSB Term 1.2
On Load on Idle
