I didnt ever consider being able to afford insurance or servicing, but after just being quoted £1000 a year insurance its totally give me the idea to buy on in April/May.
Consider tax - it may be a £400 a year job - I really don't know.
Are you getting it with a warranty? If not, if it say, throws a rod or the rear diff dies (as they can do) can you afford to fix it?
Will it be your only car? If so will you be relying on it? Seriously think about this.
I understand they need to be serviced at 4500 mile intervals, just a little research seems to clarify maybe £200 per service?
They do, usually but (not definitively) with a ABCDE service schedule in the order of ABACDBACAE
A= Oil and AYC Fluid Change plus checks
B= As A but with air filter change
C= As B but replace gear and brake fluid
D= As A but with sump washer and spark plugs
E= The nasty one - Oil Filter, Engine Oil, AYC Fluid, Air Filter, Timing Belt, Fuel Filter, Spark Plugs, Sundries
Typical pricing is below but you may get cheaper if you go somewhere like RG Motorsport.
A = Evo 4-9 4.5k service £225.00 (inc AYC)
B = Evo 4-9 9k service £299.00 (inc AYC)
E = Evo 4-9 45k service £829.00 (Including Cambelt & AYC)
I'm lucky enough to work 5mins away from home, so fuel costs are of little consequence in terms of a working week. Obviously the weekend fun will justify the other petrol usage.
I wouldn't recommend using one for that distance. Evo's can be very grumpy from cold. Gear selection/clutch usage can be difficult if the weather is very cold. It wouldn't even warm up at that distance.
What are the main differences between the FQ320 Evo 8? Worth the premium for an Evo 9?
The differences are (stolen from the MLR):
Evo IX GSR – As VIII MR plus:
• Mivec
• Larger compressor housing diffuser (16G6C)
• No spacesaver spare tyre
• Gloss black backing to front & rear lights
• Rear diffuser bumper
• Restyled front bumper with twin oval air inlets
• Different size rear oil return to block
• Plastic spoiler uprights
• Evo IX Enkei Alloys.
Available in Cool Silver, Flame Red, Electric Blue, Frost White, Amethyst Black and Solar Yellow.
Evo IX GT – As IX GSR plus:
• Magnesium Compressor wheel
• Titanium turbine wheel
• 5 speed gearbox
• GT interior
• RS Front Diff Set Up (non S-AYC)
• Improved drive train
Less?:
• Air conditioning (Opt.Extra?)
• Electric Windows (Opt. Extra?)
• Remote Central Locking (Opt. Extra?)
Evo IX MR – As IX GSR plus:
• No additional alarm fob (built into key);
• Ralliart Wing Mirrors (on some models)
• Carbon front lip
• New turbo with titanium aluminium alloy turbo fins & reduction in compressor inlet diameter (15.5)
• 17in, 11-spoke Speedline Turini alloy wheels
• Privacy glass
• Lowered ‘Eibach’ coil springs – 10mm front / 5mm rear
• Aluminium door sill plates
• Piano black dash inserts
• Available in Gunmetal Grey, not available in Black, yellow or blue.
Evo IX MR RS – As IX MR plus:
• 5 speed gearbox
Available in Solid White or Solid Red.
Less:
• Air conditioning (Optional Extra?);
• Electric Windows (Opt. Extra?);
• Remote Central Locking (Opt. Extra?);
• Recaro Seats;
• IX Enkei alloys (comes with steel wheels).
Evo IX RS – As IX MR RS plus:
Only available in Solid White?
UK models
Evo IX FQ 300 – As IX GSR plus:
• Foglight
• PIAA lights and wipers
• FQ badges
• HKS panel filter
Evo IX FQ 320 – As FQ300 plus:
• HKS Superdrager exhaust
• HKS hardpipe kit
• Keyless entry
• Ralliart sports pedals
• Puncture repair kit
Evo IX FQ 340 – As IX FQ 320 plus:
• SmartNav
• Ralliart Leather/alcantara seats
• Remap
Evo IX FQ 360 – As IX FQ 340 plus:
• Race Cat
• Ecutek remap
• Speedline 5 spoke alloys
• Triple Gauge Din Unit: battery voltage, Oil temp. and Boost (reads up to 1.5bar)
• Uprated 225 l/ph fuel pump
• Carbon vortex generator
• Carbon front splitter
Evo IX MR FQ 360 – As IX MR plus:
• Race Cat
• Triple Gauge Din Unit: battery voltage, Oil temp. & Boost (reads up to 1.5bar)
• Ecutek remap
• Leather & Alcantara seats with ‘IX MR’ logo (leather delete option)
• Carbon Vortex Generator
• 6 Speakers as standard
• SAYC changed to give increased torque differential across rear axle
• Uprated fuel pump
• "By HKS" badge on boot
• Available in Cool Silver, Gunmetal Grey, Flame Red, Pearl White, not available in Black, yellow or blue.
__________________
Only you can decide that, the changes are many but none particularly groundbreaking. I reckon the 9MR is the best looking Evo out there, particular in White.
I understand how raw they are and lack many creature comforts...but 0-60 in 4.4 seconds about says it all. I find them better in appearance to the STI too. The only downside is not having the rumble of the Impreza 4 cylinder.
Its relative. If you are used to BMW/Merc/Audi levels of comfort then you'll notice it. If not then you won't so much. It doesn't bother me in the slightest personally.
It really doesn't, merely that its a powerful car with traction off the line. Theres a lot more to it
I think they are better looking too, hence buying one. The scooby burble is desirable to some and certainly a characteristic, but I don't miss it despite the Evo having quite a subdued (read: rubbish) engine note. Plenty of other noises to keep you happy
