3 (Three) PAYG MiFi Wireless Mobile Broadband Modems
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys,
You can pre-order a MiFi dongle for creating your own WiFi hot spot - anywhere in the world. Up a mountain, on a boat, in the sea? These MiFi Adapters work without any need for a USB connection or cables to connect to your smartphone, laptop or tablet PC.
3 (Three) PAYG Huawei E585 Wireless Mobile Broadband Modem - with 3GB Data Preloaded @ £63.98 inc VAT
Topped up and ready to go. Your Huawei E585 wireless modem is already loaded with the data allowance you've chosen - just plug it in and surf away. When you run out of data you can buy a Top-up and convert it to the Add-on of your choice. Simple.
The Huawei E585 wireless modem sends out a Wi-Fi signal to give you internet connection whenever you need it. With your own mobile Wi-Fi connection (known as MiFi®) so you can connect different Wi-Fi enabled devices at once and get fast internet speeds with no wires, no hassles and no need for a Wi-Fi hotspot.
The E585 is really easy to use and fits in your pocket. Just turn on your wireless modem, switch on connection to the Three network, and select the Wi-Fi function. Then choose the Wi-Fi option on whichever device you’re using. There's no need to load any software to get online using the Huawei E585. The wireless modem gives you download speeds of up to 3.6Mbps (megabits per second) and comes with a battery that lets you stay connected to the internet for up to 5 hours.
You can charge the E585 while you're using it and it comes with on-board software that starts each time you connect it to a PC or laptop using the USB cable. The software allows you to manage your Three account, send and receive text messages and change settings for your Wi-Fi connection.
MiFi Pay As you Go + 3
- No wires, no hassles
- Quad band - works worldwide (SIM support may vary, check with carrier)
- Mobile Internet access at broadband speeds
- Download speeds up to 7.2 Mbps (speeds may vary)
- Plug’n’Play installation on Windows (2000, XP, Vista and 7) and Mac (10.4 and 10.5)
- MicroSD card slot, up to 32GB. (Card not included)
Only £63.98 inc VAT.
ORDER NOW
3 (Three) PAYG Huawei E585 Wireless Mobile Broadband Modem - with 12GB Data Preloaded @ £116.99 inc VAT
MiFi Pay As you Go + 12
Only £116.99 inc VAT.
ORDER NOW
I have used these with a few mates at LAN parties and I got to say they are a life saver when you need an internet connection at a venue with interwebz. Great piece of kit.
Off topic but anyway- Loki, if the link in your sig is your website you may want to double check things as its showing the joomla installer.
Sorry, what are these? Are they like the ****y dongles you get from mobile phone providers?
They are ;) http://www.three.co.uk/Mobile_Broadband/MiFi
I used one of these with my iPad. Very light weight and small. Brilliant when the broadband goes down.
I bought mine months ago from 3 for £50.00 then so much per month. Now using a 3GB sim card which lasts for 3 months, bought one a couple of days ago for £6.80.
The battery is pretty good on them as well, 3 say up to 5hours. When I was visiting family a few weeks ago, I just left it plugged in on charge for hours, worked great :)
Dimensions: 86 x 46.5 x 10.5mm
Weight: 90g
£71.99 now on 3 website without a sim card with data usage on, so these are at a nice price!
These look fantastic, think I'll get one for me and a colleague for laptop and phone usage when away from home/office or when broadband is down!
According to the Three website, it appears that a mobile broadband solution would possibly be faster than my really poor normal connection in my area. :eek:
Tempted. Can't say I actually need one, but it's the kind of product which activates the geek instinct in me.
Is there any difference between the two products above, apart from the amount of data preloaded? If not, you're paying £50 for 9GB of data? You can get a SIM with 3GB of credit preloaded for about £7...
It doesn't seem like it. Buying the first one then extra cards makes 1000* more sense!
And if anyone cares, of the top of my head these takes about 45seconds to boot up and connect
Are these things really worldwide? Looking to do a bit of travelling over the summer (as in, most of europe and all the way to mongolia, no points as to guessing why, see sig) and this would be kinda awesome to update the blog!
Well I put in my Virgin Mobile sim last week and found out the MiFi is locked so. You can obviously only use 3 SIM cards.
If you can use the card overseas I bet you would be charged and it wouldn't come out of the data usage which is on the SIM.
While I like the idea of this, I can't help but feel it's terribly undercut by sharing the internet connection from a mobile phone with a laptop. I already have internet wherever I go, as I have a phone in my pocket.
In fairness I don't know if my phone can share it's connection with several computers at once. However I'm pretty certain 7 can set up a laptops wifi card as an access point, and simultaneously use internet connection sharing with a phone.
So, I think it's a clever idea, but I don't understand where the market is.
