New cooler on the block!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
New Monster CPU cooler just landed.
Prolimatech Genesis Mega Performing CPU Cooler (Socket LGA775/1366/1155/1156/AMD AM2/ AM2+/AM3) @ £64.99 inc VAT
Tower CPU heatsinks have been mainstream for the past few years. While power end users may consider them to be pinnacle when it comes to performance, there are others who would prefer down draft low profile heatsinks for their versatile ability to cool not just the CPU but also its surrounding components such as RAM, MOSFET, and Northbridge chipset heatsink. Genesis combines the best of both worlds with top-notch engineering design and superior built quality and performance that are surpassed by none. Either 120mm or 140mm can be installed on the Genesis for a maximum installation of 3 fans of your choice! If you are looking to overclock your CPU to the max while keeping your system stable, we highly recommend the ultimate CPU heatsink, Genesis. The New Era of Super Cooler has arrived.
- High clearance for better motherboard compatibility
- Massive cooling range; cools not only CPU but also MOSFET and RAM
- Cooler surrounding temperature allowing more stable environment for higher overclock
- Takes both 12 and 14cm fans for a maximum installation of 3 fans
- Six high quality heatpipes for effective heat transfer
- Light weight at 800 gs (without fans) in the highend class
- Intel and AMD platform supported. All mounting hardwares are included
- Suggested Fans: 800-1600 RPM
- 6 x 6mm heatpipes
Only £64.99 inc VAT.
ORDER NOW
What the .......................
That's WEIRD!!!
Got any figures for this thing? Comparisons with things like the Megahalems/D14/Silverarrow etc...?
kd
We are currently testing this and will have benchmark results soon.
Fans are not included, I added the fans for the photo shoot.
this designed to eliminate the problem of fouling ram slots?
not the prettiest solution ever is it lol. How well does it cool?
Really want to see that installed in a rig with some pics to get an idea of how it works - it's certainly...unconventional.
Really pleased with my Megahalems though so interested to see what this can do :)
It would be intresting to put it against the megahalems/supermega, ND14 and the Silverarrow.
You say you are currently testing it, are you testing it against other coolers or solo?
New flagship cooler I think! - We tested it with 2 x 1000RPM Sharkoon Fans.
Intel i7 920 idling
Intel i7 920 @ stock - full load
Intel i7 920 @ 4Ghz - full load
Wow only 5C difference from stock/4Ghz at load is amazing.
Have you got any pics of it fitted?
Would also be interested in HWmonitor load pictures to see temps of NB etc
could you push pull on main heatsink? And clearance of the RAM like?
