It's on iTunes - just very slow 3 hrs remaining zzzz
Only compatible with 3gs, 4, and iPad (plus some ipods)
FTTC has paid for itself at last![]()
Itunes tells me that there is a new version, so I download it, it installs, asks to restart my computer then when you run Itunes it errors with the following message....
Itunes cannot run because some of its required files are missing please reinstall Itunes.
Ok no problem, I'll just download Itunes from the Apple site. Went to install it and got the "there is a newer version of itunes installed on your computer" message.
/sigh
http://www.felixbruns.de/iPod/firmware/
If you can't download, try the link above.
I'll be waiting for a jailbreak. Nothing important in this anyway for 1st gen iPad *i think*
The only thing what comes to mind is the mute switch option, but I'm jailbroken anyway so solved that
Always a bonus!fixed WIFI is the main one for me![]()
