The dual Fermi that was never released.
25 Sep 2009
Don't know if this is a repost or not, but enjoy.
(Google translated Chinese, prepare for bad English....)
"From the exposure image, we can see that this is a single card dual GPU graphics card, put the front two chips GF104-325-A1, 2 GPU middle of a bridge chip. A positive place total of 16 Samsung 0.4ns GDRR5 memory, Each GPU has its individual stars 1GB memory and 256bit memory interface. and graphics negative, in addition to a large number of "beans" Tantalum and MLCC, but also equipped with four high-speed NEC Proadlizer thin film decoupling capacitor, which greatly reduces power supply noise, high storage capacity and ultra high-speed charge and discharge efficiency, can greatly enhance overclocking ability and stability. The new dual-core graphics card also uses stunning white PCB, the PCB is configured with a jumper on the upper left corner. The power supply, the two cores using a total of eight-phase power supply, memory for the two-phase power supply, the core CHiL CHL8314 using digital PWM.
According GALAXY related news, the GPU core with special challenges, together with luxury power supply circuit, very powerful overclocking capabilities.
More on the follow-up report on this card
http://www.galaxytech.com/zh-bg/"
http://computer.uwants.com/redirect.php?tid=11655463&goto=lastpost#lastpost
http://www.engadget.com/2011/03/10/visualized-nvidias-dual-fermi-card-that-never-was/
2 8-pin PCI-E power
Wider than normal card
2 fans?
4 DVI, 1 DP
Imagine that with a White Silverstone RV02W-EW Raven 2 Evolution Windowed Case, black motherboard with white braided cables going to the motherboard and black braided cables going to the white graphics card :o
My trousers are all messy now.
the 460x2 should be very interesting if it ever makes the market
Even more pointless than the 6990/590gtx, at least with those two if you have silly money you can go quadfire/sli pretty easily with only two slots and lots of space between, with 4 separate cards you've got heat, noise, no airflow and very little compatibility in terms of mobos that can run it.
WIth a 460gtx you can't do quad sli, no reason not to get two single cards, better clocking, temps, noise.
There were a good half dozen various dual gf100/gf104 designs leaked throughout the last 8 months or so, none made it to market, not really sure why, apart from this absolute insistant by Nvidia/AMD to make their official cards dual slot with blower fans which is asking for trouble. Considering the pci-e spec allows 2x8pin pci-e connectors and triple slot coolers, meh.
PCB's interesting but I've always bought substance over style, also in a Raven case wouldn't the white of the pcb be facing the back of the case so you basically wouldn't see it, while in a "normal" case it would be facing up and easier to see?
