[TW]Fox;18651854 said:
It doesn't, but the more you borrow the more money you pay in interest
Of course, but if you're already entertaining the idea of taking a loan anyway, then you understand that borrowing is generally more expensive than buying with cash.
To my mind, affordability is based on being able to buy the car with manageable monthly payments without ever going into negative equity in case something bad happens, ideally with a grand or two set aside 'just in case'. Simple contingency planning.
If you don't have 40-50% equity to put down, it stands to reason that the financing costs are going to be higher, but to imply that is only affordable if you have that capital is inaccurate imo.
The only reason I can see for putting down a deposit is if you're buying a sufficiently new car that will depreciate faster than the monthly payments will cover initially. As per my interpretation of affordability above, I would agree that buying for example, a 2008 335i M Sport for ~£20k is likely to depreciate faster than say, a £300 a month loan repayment will cover. In which case it would be sensible to put a chunk of cash down as a deposit or set it aside as a slush fund if required.
A ~£10k 2005/6 330i Sport is unlikely to depreciate faster than the £300 a month loan repayment, so it is affordable, and the deposit is not neccesary.
'Deposits' with cars make me uncomfortable. I associate them as a dealer trick to fudge the numbers to make a new high depreciation risk car look more affordable. If you arent able to re-save the amount you've just laid down in time to buy a new car in a few years time, then you can't repeat the process and buy the same 'standard' of car again.
Definately put more capital in.
Put in 7k capital and take a loan of 7k. Car value drops for example by 7k and you sell said car. You pay off the loan and thats the end of story.
Take a loan of 14k, car drops 7k in value, you pay off 7k of loan and still left with several more k for the rest of the loan. So even after you sell the car you are still paying it off. You then need a replacement car, your still paying out on the old one, you need a loan on a new one and slowly your debt increases...
If your car depreciates by half, you've either had sufficiently long that the loan repayment really should have covered at least the depreciation, or you've bought a car that is too new, and in Mark's words blown your brains out on depreciation. To my mind, the error in the latter scenario is buying a new car, rather than not having managed to save £7k before buying it.
