Case to Mount on a the back of my TV
14 Mar 2005
Here and There...
I currently have a REVO mouted on the back of a small LCD in one room in my house which I use for music play back. Havng finally got a Plasma for the living room we now want something similar, I'd get another REVO but the price is putting me off. So what I'm hunting for is a small PC case that I can mount to the back of my tv without any modifications that will accomodate one of the new AMD Fusion boards and a single laptop size hard disk. Needs to be quiet, looks not importnat as it will be hidden!
I'm assuming you want a case that can be VESA mounted?
a quick google for 'VESA mount mITX case' should give you plenty of options.
Did a quick google, and there seems to be quite a few available anyone got any perosnal experience, I want to avoid to many screaming 40mm fans allthough I'm sure most of these cases could be run passive.
Remember that the back of your TV will generate quite a bit of heat (my plasma does anyway...) so passive cooling might not work... Does look like a good idea though!
It does get pretty warm ehind the TV but this little box won't exactly be pushed o breaking point playing a few MP3's and streaming the odd film. There is quite a lot of space so convectional airflow should be good.
