- 9 Mar 2011
Hi have just upgraded from a 5770 to a 6950 that i got from here a few days ago.
The card is fine until under load then on almost every game it starts flickering, not on and off, but with like transparent lines refreshing down the screen (hard to explain).
It only does this once its under load its fine otherwise.
My first thought was drivers, it was running on the latest 11.2 drivers, so i ran driversweep and set them to 10.5a - still the same, i swept the drivers again and used the off the cd drivers but its still the same.
I also at the moment have a VGA cable plugged into the DVI slot with an adapter (A DVI-D cable is on the way) but if this does not help, does anyone have any ideas?
Thanks.
Thanks.
