- 7 Dec 2008
Hi guys, I have a "Asus Rampage III Extreme X58 Socket 1366 8 Channel HD Audio ATX Motherboard " hopefully arriving tomorrow. I have bought it to replace my Gigabyte UD7A X58 Motherboard. First I will explain my reasons for doing this.
If you look back through my posts you will see the horrendous heat problems iv been having with 2 580s running SLI. I have tried more fans, I have tried angling my cards for more airflow by stretching them apart. I have even tried purchasing a new case, going from my Antec 1200 to a Coolermaster Cosmos 1000. Nothing has worked, I had 2 other options left, either go water cooling which means of course physcially taking my cards part (No thankyou) or buy a new motherboard. I opted for the latter.
I KNOW for a FACT because my friend has the EXACT same specs as me only with a motherboard with more spaced out PCI-E slots that all I need to do is just not sit my cards so close to each other, but because the UD7A is totaily useless at doing this (being an high-end motherboard, I am shocked by this, what the hell do I need 2 PCIx1 slots next to each other for) so I have bought one that I know allows more spacing : )
Now I do have a question I would like to ask of you guys, I have never installed or swapped out a processor before, is it easy? I am assumeing its just a case of cleaning it up and then slotting it into my new board and then just attach the heatsink as normal.. this is the case right? Nothing special I am missing? Whats best to clean it with? Can you name a product?
Thanks guys : ) Hopefully I have chosen a good motherboard, cost me enough : ( But for the money thats in this machine, I can't afford to keep having to mess around with it, doing my nut in.
