Caporegime
- 18 Oct 2002
Theres two sets of things in a Nuclear reactor, afaik, you've got essentially two separated systems, the internal one has rods exposed to water, this turns to steam, goes up, turns the turbine, the goes through a cooling system to bring it back down to liquid, drop and get turned back to steam. Thats basically completed sealed system to contain the radiation.
The cooling system is, its like having a pc watercooling, but instead of using air to cool the radiator, you use coolant(which I gather isn't "just" water) but its cooling pipes that are sealed and presumably radiation proof so big lead pipes. But the inside water stays inside.
When the cooling system stops working, you just get the hot water continue to increase in temps and more and more gas is produced, thats where the pressure build up comes from, they have backup containment buildings to vent the gas into to reduce the pressure in the actual reactor, and when the pressure in those buildings gets dangerous its better to vent some of it, than to have a full on explosion from the pressure as after that there would be no way to seal it.
http://science.howstuffworks.com/nuclear-power3.htm
at a guess yes, that would be just about right.
THe cooling system is on the right in that little diagram, basically it pumps cool water/coolant through pipes into a sealed building to help cool the gas. Theres no pressure on the cooling side basicallly, it pumps water in then it gets cooled itself in huge cooling towers, or in an ocean based cooler as in several of these plants.
The pressure build up is inside that sealed area on the left, thats all radiactive. Reading more, there are two types of plants, some have the intermediate system so its got essentially an extra level of radiation prevention, I'm not sure which type the Japanese have.
