£400 budget gaming pc
12 Mar 2011
i am new to pc building and have no idea of what a good rig consists of ..... HELP!
i had a look at components and came up with this setup
Intel Core i3 540 306 GHz processor
ASUS P7H55M motherboard micro ATX iH55
2xOCZ 2GB DDR3 1333MHz Gold Memory Module CL9 (9-9-9-20) 1.65V
Samsung HD103SJ Spinpoint F3 1TB Hard Drive SATAII 7200rpm 32MB Cache EZCool NA-705 Case - Black (500w PSU) (http://www.overclockers.co.uk/showproduct.php?prodid=CA-043-OP)
KFA2 GT 240 1GB GDDR3 VGA DVI HDMI Out PCI-E Graphics Card
LiteOn IHAS124-19 24x DVD±RW DL & RAM SATA Optical Drive - OEM Black with Nero Essentials
was just wondering if im on the right track or if anyone has any better suggestions
Thanks lewis
Hey mate, first of all, you might want to delete the competitor's links as they are against the forum rules.
As for your build, have you got a power supply already? cause I don't see any listed there. And you might also need a dvd unit
PSU is with the case ;)
Personally i would go for a AMD processor on a budget and maybe a different graphics card.
The Ocuk case inludes a psu, have you looked at Sandy Bridge setup.
Indeed Remove the links before a don sees ;)
here's my 2 cent's just over budget. This is what i would be looking at for a £400 gaming pc:)
Your basket
Price Line Total
Gigabyte GeForce GTX 460 OC 768MB GDDR5 PCI-Express Graphics Card £124.99
(£104.16)
£124.99
(£104.16)
AMD Phenom II X4 Quad Core 840 "95W Edition" 3.20GHz (Socket AM3) - Retail £79.99
(£66.66)
£79.99
(£66.66)
Coolermaster Elite 430 Windowed Case - Black (with 500w Elite Power PSU) £64.99
(£54.16)
£64.99
(£54.16)
Asus M4A88T-M AMD 880G (Socket AM3) PCI-Express DDR3 Motherboard £53.98
(£44.98)
£53.98
(£44.98)
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) £35.99
(£29.99)
£35.99
(£29.99)
Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache - OEM (ST3500418AS) £28.99
(£24.16)
£28.99
(£24.16)
Samsung SH-S223C/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM £13.99
Sub Total : £335.77 Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout)
Shipping : £10.50 VAT is being charged at 20.00% VAT : £69.25 Total : £415.52
Here is what i went for :
HIS ATI Radeon HD 5830 1024MB GDDR5 PCI-Express Graphics Card £119.99
(£99.99)
AMD Athlon II X4 Quad Core 645 3.10GHz (Socket AM3) - Retail £89.99
(£74.99)
(£54.16)
Asus M4A78LT-M 760G (Socket AM3) DDR3 Motherboard £49.99
(£41.66)
OCZ Special OPS 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (OCZ3SOE1600LV4GK) £35.99
(£29.99)
(£24.16)
(£11.66)
Total : £415.93
Edit : that is including £10 for postage
Your basket
Price Line Total
(£104.16)
£124.99
(£104.16)
(£66.66)
£79.99
(£66.66)
(£54.16)
£64.99
(£54.16)
(£44.98)
£53.98
(£44.98)
(£29.99)
£35.99
(£29.99)
(£24.16)
£28.99
(£24.16)
DPD Next Day Parcel
couldnt agree with this build more. its almost exactly the same as my own PC.
however, if you are concerned with fan noise, then i would highly reccommend getting a custom CPU cooler, because the AMD standard cooler is incredibly loud under load. im not sure exactly how loud, but it completely drowns out a 50 decibel grahics card. if your ok with a loud computer then dont worry about it
thanks for all the help guys
really helped me with this
decided to go with this setup
Asus M4A78LT-M LE AMD 760G Socket AM3 DVI VGA Out 8 Channel Audio mATX Motherboard
OCZ Platinum 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Ultra Low Voltage Dual Channel Kit
SAMSUNG RETAIL INTERNAL 22x DVDRW SATA BLACK
lets just hope my building skills are up to scratch
