gtx470 watercooled sli
14 Apr 2010
swanley,kent
hi,i just bought myself another gtx470 to put in sli,now i have my one watercooled with the ek nickel full block and will be doing the same with the new one.can someone point me to the right water sli connector to use with the gigabyte ud3r board.not sure if these come in different sizes.cheers
There's a thread similar to this in the overclocking section. Rjkoniell suggested a bitspower dplug thing in there. Or as jrwagh333 suggested you could use a bit of tubing.
You can use a bit of tubing, or you can get an SLI fitting which is adjustable and you just buy the one that is for the right amount of spacing between your cards, these are only a few quid.
You can see my one in this pic:
