- 21 Oct 2004
- Wales
I am looking to upgrade my CPU/Mobo/Memory from what it is now. My budget is 320 and I am mostly a gamer with occasional video editing, does anyone have any suggestions?
http://www.overclockers.co.uk/showproduct.php?prodid=CP-368-IN&groupid=701&catid=6&subcat=1275 - i5-2500k cpu
http://www.overclockers.co.uk/showproduct.php?prodid=MB-447-AS&groupid=701&catid=5&subcat=1906 - Asus P8P67 Motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=MY-203-CS&groupid=701&catid=8&subcat=1517 - 4gb 1600mhz ram
that just about squeezes into your budget, a retail 3yr warranty cpu will push the budget up by another £30
What about CPU cooler? OEM dosen't have one.
Good choices though.
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - http://www.overclockers.co.uk/showproduct.php?prodid=CP-368-IN
Asus P8P67 Intel P67 (Socket 1155) DDR3 Motherboard - http://www.overclockers.co.uk/showproduct.php?prodid=MB-447-AS
OCZ Platinum 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Ultra Low Voltage Dual Channel Kit - http://www.overclockers.co.uk/showproduct.php?prodid=MY-221-OC
316.97 inc Free Delivery
How does this sound?. Oh and I was thinking of buying a cooler in the same month, just not at the same time due to money constraints.
cookeh pack it in son, who in their right mind as a gamer would go for the non 'k' cpu
There is no way an overclocked Phenom 2 can match either.
It is also worth noting that crossfire is available to both![]()
MSI P67A-C45 Intel P67 £104.99 inc VAT
OCZ Platinum 4GB (2x2GB) DDR3 1600MHz Dual Channel Kit £29.99 inc VAT
Intel Core i5-2500K 3.30GHz OEM £161.99 inc VAT
Cooler Master Hyper 212 Plus CPU Cooler £20.99 inc VAT
total = Total : £329.35 inc vat & del ( £9.50 )
or £320 inc free del which you qualify for.
or £320 inc free del which you qualify for.![]()
Beg pardon?
Show me your K series chip within budget then?
Also, I assume everyone overclocks?
And yes, it can, a Phenom II at 4GHz can match a standard clocked SB in some games, hell a stock one beats SB in some applications.
Yeah, fair point. Should have made my point of "proper" symmetrical CF
Another winner? You forgot a coolerAnd it was over-budget already.
Please grow up, forums are not a competition.
Honestly from looking at it....i probably should increase my budget a little. Its not a big deal, its just something i'll have to work out. Thankfully I'll be selling up my Q9550 around about the same time so that could pay for a good cooler![]()
Worth noting OP that the board isn't B3 revision - meaning its susceptible to the USB 2.0 failures that affect some H/P67 chips; and you won't get CF or SLI - not such an issue if you have no plans to CF or SLI ofc![]()
actually Cookeh it is a B3 Revision board, i accidentally deleted that part from the description whilst i was inserting the price link![]()
