Asus GTX 570
19 Apr 2010
I currently have a GTX 570, and i was thinking of buying another for an SLI setup. But they have stopped selling the reference (Which my original is).
So, i was looking at the Asus GTX 570 Direct CU version and I was planning to put my reference on the bottom as not to block the air intake.
So yeah, would i be able to SLI them? They both have the same OC aswel.
Thanks.
Thanks.
Isn't that triple slot? or am i thinking of the direct CU II
If it's this one then you can't have it on top unless your mobo has the space.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-250-AS&groupid=701&catid=1914&subcat=1010
As a note, there's nothing stopping you getting a reference card from a different brand if that's the sole reason you're getting the Direct CU II. Otherwise, it's a very good card and not too badly priced. Just make sure you have the space for it and remember that the card is longer than the reference card at 28.75cm so check that it will fit.
